Trend log stopped working - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Trend log stopped working (/showthread.php?tid=2418) |
Trend log stopped working - spyder - 08.01.2020 Hi all, All my trend logs stopped working after a power loss. No errors in the logs and my SD card seems to work properly. Creating a new trend log works, but I would like to revive the old ones to avoid losing all the past data. Any ideas? Thanks RE: Trend log stopped working - Daniel - 09.01.2020 If you reboot do you still have the new trends? RE: Trend log stopped working - spyder - 12.01.2020 (09.01.2020, 09:08)Daniel. Wrote: If you reboot do you still have the new trends?Yes, they keep working. RE: Trend log stopped working - Mr.D - 23.01.2020 Does anyone know if multiple trend logs impact CPU/IO... I am constantly seing between 0,5 to 0,9 in CPU/IO, and this is a SpaceLYnk for home use, so it is not that many objects that keep writing on the bus at any given time RE: Trend log stopped working - admin - 24.01.2020 Trend data is stored once a minute so it can slightly increase the system load but not by a large amount. You can install Processes app to see what is causing the most CPU load on your device. |
