Activate RS-485 second port on LM5 lite - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Activate RS-485 second port on LM5 lite (/showthread.php?tid=2419) |
Activate RS-485 second port on LM5 lite - Auzzii - 09.01.2020 Hi, I need to use 2xRS485 on LM5 Lite. on RS485-1 all is working, but on RS485-2 not. (seems to be using rs232) Script: if not port then require('serial') port = serial.open('/dev/RS485-2', { baudrate = 9600, parity = 'even', duplex = 'half' }) port:flush() end if port then char = port:read(1, 1)--send back if read succeeded if char then port:write(char) end end Tnx. Auzzii RE: Activate RS-485 second port on LM5 lite - Daniel - 09.01.2020 Hi Try to run this self check https://forum.logicmachine.net/showthread.php?tid=1939&pid=13139#pid13139 |
