Bacnet Scan doesnt find any bacnet server - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Bacnet Scan doesnt find any bacnet server (/showthread.php?tid=2427) |
Bacnet Scan doesnt find any bacnet server - batistacaceres - 17.01.2020 Hi: When I try to scan devices using BACnet client application, it doesnt find any bacnet server, even when there is an logicmachine as bacnet server. That happend when i update my logicmachine with a new firmware (lm5m3-20191015.img). May be some bug in that firmware?, if I update to firmware (lm5m3-20180828), now IT WORKS. May be this last firmware, is having problem with the Whois command in bacnet? I have tested this in several devices and always happen. best regards RE: Bacnet Scan doesnt find any bacnet server - admin - 17.01.2020 You cannot run both BACnet client and server on the same device and on the same port. Disable server before running scan. RE: Bacnet Scan doesnt find any bacnet server - batistacaceres - 17.01.2020 (17.01.2020, 13:43)admin Wrote: You cannot run both BACnet client and server on the same device and on the same port. Disable server before running scan. I have two logic Machine, one as bacnet server, and the other one as bacnet client. The LM as bacnet server works very well, it serves data to other devices. The problem is with the LM as Client bacnet, when I try to discover the LM as bacnet server (using BACnet Client app) it doesnt find it. But it just happen just with the last firmware, when I back to firmware (lm5m3-20180828), the BACnet Client app then start discover LM as servers. Any suggestion.. LM as server: Server enabled: true port: 47808 Object priority: 16 "1/1/5" testobject: object property Export selected LM as client: server enabled: false port: 47808 Object priority: 16 App installed: BACnet client best regards RE: Bacnet Scan doesnt find any bacnet server - admin - 20.01.2020 Try this firmware: https://dl.openrb.com/lm-20-imx6/lm5m3-20200116.img RE: Bacnet Scan doesnt find any bacnet server - batistacaceres - 21.01.2020 (20.01.2020, 12:01)admin Wrote: Try this firmware: https://dl.openrb.com/lm-20-imx6/lm5m3-20200116.img Hello admin: yes, yes.... I have tested it, .. at first, it works very well, thank you very much... best regards.. RE: Bacnet Scan doesnt find any bacnet server - knxkike - 21.01.2020 Hi! I had the same issue! I could not combine these two functionalities in the new firmware. When I roll back to an older firmware every thing works fine. I had just try the new firmware and everything is working fine again! Thanks to the team!! RE: Bacnet Scan doesnt find any bacnet server - MarcusH - 09.07.2020 Hi, im testing bacnet client now and i get the error "Cannot run scan while local BACnet server is running on the same port" even though server is off. I got the newest firmware, but im not sure if i understand the client description correctly. It says that it can find servers and you can map maximum 50 and thats fine. My servers got 1476 active objects, but i only need a few. Is this too much for the LM to be able to "find" it in the client? Or is there a bug in the client software? When i use an external bacnet software it finds everything and maps it out in seconds.
RE: Bacnet Scan doesnt find any bacnet server - Daniel - 09.07.2020 It will most likely not find this amount of objects. You can still use the 'none app' bacnet version and map by script when you know the objects parameters. RE: Bacnet Scan doesnt find any bacnet server - MarcusH - 09.07.2020 (09.07.2020, 08:49)Daniel. Wrote: It will most likely not find this amount of objects. You can still use the 'none app' bacnet version and map by script when you know the objects parameters. Okey, thank you
