Customize the visualization - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Customize the visualization (/showthread.php?tid=244) |
Customize the visualization - silvestro - 08.03.2016 How can I customize the software interfaces via CSS with my logo and my colors? RE: Customize the visualization - admin - 08.03.2016 You can edit visualization CSS in Vis. graphics -> Edit custom CSS. Main Logic Machine interface and System Config cannot be customized. RE: Customize the visualization - severian - 13.07.2016 If I understand correctly, for trend and schedulers, we cannot change the text by translation? RE: Customize the visualization - Erwin van der Zwart - 13.07.2016 Hi Severian, You can't change text with css, css is designed only for setting properties. The language of trends and schedulers are following the selected language that can be set in general config. If your language is not available you have a challenge (: BR, Erwin |
