Blinds Control - Multiple Socket Connections Per Script - Printable Version
+--- Thread: Blinds Control - Multiple Socket Connections Per Script (/showthread.php?tid=2459)
Blinds Control - Multiple Socket Connections Per Script - jamesng - 09.02.2020
I'm trying to control Somfy blinds by issuing an UP or DOWN command followed by a STOP command a few seconds later to achieve a partially open blind.  ie: to automatically open the blind 30%.
I'm making a socket connection to the Somfy controller - this works fine - however I don't seem be able to send two separate commands over two socket connections from the one event-based script.  The second sendCommand never gets sent.  The controller is able to receive multiple commands ok when triggered from separate buttons / scripts within the same timeframe.
Is there a different way to code this so that the LUA sends the second command?
Thanks in advance
Kind Regards
James
FUNCTION
function sendCommand(command)   local socket = require("socket").tcp()   data, err = socket:connect('192.168.1.200', 4999)   data, err = socket:send(command .. '\x0D\x0A')  end
SCRIPT
BlindsTravel = 22; -- Time in seconds to fully open/close BlindsStep = math.round(100/BlindsTravel);  -- Number of percentage steps to move per second BlindsNewPosition = GetUserParam('Wired', 'BlindsNewPosition'); BlindsCurrentPosition = GetUserParam('Wired', 'BlindsCurrentPosition'); -- Move Blind Down / Open if (BlindsNewPosition > BlindsCurrentPosition) then     sendCommand('0113D\x0D\x0A'); -- Send down command       while (BlindsNewPosition >= BlindsCurrentPosition) do         -- Update current position of blind during movement      os.sleep(1)     BlindsCurrentPosition = BlindsCurrentPosition + BlindsStep;     SetUserParam('Wired', 'BlindsCurrentPosition-Study', BlindsCurrentPosition);           -- Stop blind when blind has moved to new position     if (BlindsCurrentPosition >= BlindsNewPosition) then       sendCommand('0113S\x0D\x0A');  -- Send stop command (never gets sent)     end;            end; end;
RE: Blinds Control - Multiple Socket Connections Per Script - Erwin van der Zwart - 09.02.2020
To close a command you probably need to send \r  to be able to send the next, try to a add this into your sendcommand function  '\x0D\x0A' .. '\r'
RE: Blinds Control - Multiple Socket Connections Per Script - jamesng - 09.02.2020
Hi Erwin,
That still didn't work either .. the first command executes however the second one does not.
Even in a really simple example, the second command doesn't execute with the added \r.  For example
function sendCommand(command)   local socket = require("socket").tcp()   data, err = socket:connect('192.168.1.200', 4999)   data, err = socket:send(command .. '\x0D\x0A' .. '\r')  end sendCommand('0113U');  os.sleep(1) log('Sleep 1') sendCommand( '0113S');  log('Sleep 2')
If I split this into two separate scripts and run the first one, then the second one a second later the commands execute as expected - however if I call sendCommand twice from the same script, the second calls fails (and I never see 'Sleep 2' in the logs.
Any idea why this would be happening?
Kind Regards
James
RE: Blinds Control - Multiple Socket Connections Per Script - admin - 09.02.2020
'\x0D\x0A' is the same as '\r\n' so extra '\r' is not needed
I think the problem might be with multiple connections which the gateway might not handle properly. Try sending two commands in the same connection:
sock = require("socket").tcp() sock:settimeout(5) res, err = sock:connect('192.168.1.200', 4999) if res then   sock:send('0113U\r\n')   os.sleep(1)   sock:send('0113S\r\n')   sock:close() end
Hi That seems to work. Many thanks!
Kind Regards
James
