Write in a Single Bit of a Word - Printable Version
+--- Thread: Write in a Single Bit of a Word (/showthread.php?tid=2475)
Write in a Single Bit of a Word - UfficioTecnicoEE - 14.02.2020
Hello Everyone,
I have to write a single bit of a register with a boolean value.
Can you help me with a script?
In the attachment you can find the register that I have to use.
For example I have to command the Bit0
Thank you so much at all!
Luigi
RE: Write in a Single Bit of a Word - admin - 14.02.2020
See this: https://forum.logicmachine.net/showthread.php?tid=2464&pid=15619#pid15619
RE: Write in a Single Bit of a Word - UfficioTecnicoEE - 14.02.2020
(14.02.2020, 12:10)admin Wrote: See this: https://forum.logicmachine.net/showthread.php?tid=2464&pid=15619#pid15619
Thanks for your reply, but I'm a beginner in this things.
Why I have to calculate the value of 3 object together? The post that you send me is good for 1 object also?
Thank you so much for your patience
Example can be changed to accept any number of input objects.
If you want to convert boolean value to a number you can do this via an event script (1/1/2 is output object):
value = event.getvalue() out = value and 1 or 0 grp.write('1/1/2', out)
(14.02.2020, 12:15)admin Wrote: Example can be changed to accept any number of input objects.
Sorry, I explain all my situation so I can understand all better.
I have created a script that read all the bit of a register (in this case the register 1280):
require("user.GetBit") local value local Status local Byte        -- Matrice di valori --- Modbus --- mb = require('mbproxy').new() mb:setslave(1) -- Lettura variabili —— Status= mb:readregisters(1280) ---- Byte --log (Status) if Status ~= nil then   Byte = {getbit(Status, 0),     getbit(Status, 1),     getbit(Status, 2),     getbit(Status, 3),     getbit(Status, 4),     getbit(Status, 5),     getbit(Status, 6),     getbit(Status, 7),     getbit(Status, 8),     getbit(Status, 9),     getbit(Status, 10),     getbit(Status, 11),     getbit(Status, 12),     getbit(Status, 13),     getbit(Status, 14),     getbit(Status, 15)   }   log (Status)     for i=0, 16, 1 do       grp.update ('Stato.reg.1280_Bit' .. i ,Byte[i+1])   end end mb:close()
so at my address 32/1/1 there is the boolean value of the Bit0 of the register 1280.
Now I have to command the Bit0 of the register n°1280 with a boolean value.
Can you please write me all the script, so I can write it for the other commands.
Thank you very much and sorry for bothering you.
RE: Write in a Single Bit of a Word - Daniel - 14.02.2020
Read this thread https://forum.logicmachine.net/showthread.php?tid=1922&pid=11915#pid11915
This should explain you all what Admin has in mind.
Thank you very much both!
So this script is correct if I wanna set Bit0 of register 1280 to 0 when 32/1/1's value is 1
function setbit(value, bitnr)   local mask = bit.lshift(1, bitnr)   return bit.bor(value, mask) end value = 0 if grp.getvalue('32/1/1') then   value = setbit(value, 0) end log(value) mb = require('mbproxy').new() mb:setslave(1) -- set register at address 1000 to 123 mb:writeregisters(1280, 0) mb:close()
And another question the 123 near the code below what value is??
This line is just the comment 123 is the value you write. in line 18 instead of 0 you should have value
Now I have to set bit 3 of register 1280 to 1
This is the right code?
require("user.SetBit") mb = require('mbproxy').new() mb:setslave(1) value = 1 if grp.getvalue('32/1/29') then   value = setbit(value, 3) end log(value) mb:writeregisters(1280, value) mb:close()
