decimals - Printable Version
+--- Thread: decimals (/showthread.php?tid=2483)
decimals - GIA - 20.02.2020
Whats the way to change the decimal places in Touch visualisation? (from 2 digits to 1)
And why can temperature element only jump one degree and not 0,5 degrees? ( I have changed the parameters in objects )
DPT: 09.001 and tested 2 byte floating.
RE: decimals - Daniel - 20.02.2020
I don't see such option in SE Touch. In Mosaic it exist since a while. You have to wait for update.
RE: decimals - Tokatubs - 20.02.2020
(20.02.2020, 15:11)GIA Wrote: Hi,
Second one is found in the elememt. You have step. Default 1. Can be set to 0,1 and 0,5.
Første tror jeg kan fikses sånn:
Maybe the simplest way is:
enter objects.
Filter by data type, choose 09.001 temp
click mass edit
choose visu parameters
then choose 1 desimal and 0.5 on step.
save
RE: decimals - GIA - 20.02.2020
no there is no such parameter in the element for this.
se picture.
enter objects.
click mass edit
save
enter objects.
click mass edit
save
I have also tried this with no luck!
Nothing works, so I am a bit surprised over my "new wiser adventure"
Object parameters work only in custom visu. They have nothing to do in Touch (Mosaic)
ok, so i hoped I could build a fast working visualization with the touch function, but this is a new feature, that is not very testet or.....?
Touch is few versions behind Mosaic, one day it will be updated.
I had a look in ETS, and it is not possible to change Schneider`s Multifunction RTCU to adjust 1 degree either, so I have to live with this strange solution for now...
(Do not have the sparetime to create a nice looking custom visualization)
