IP camera URL - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: IP camera URL (/showthread.php?tid=249) |
IP camera URL - Sebastiaan - 14.03.2016 Hi everyone, I linked some IP-cameras with the visualisation in LM4, everything works fine inside the same network as LM. I opened the necessary ports on my router for external access to my visualisation at home. Everything works fine here, except the camerastreams. To make these streams visual, i use the camera-url function with an internal URL like http://user:password@192.168.0.50/stream1.mjpg. I think that when i login from outside my own network, this URL is not looked up in the network of LM, but in the client-network. Anyone experienced this or found a solution for this issue? Thanks in advance, Sebastiaan Belgium RE: IP camera URL - buuuudzik - 14.03.2016 (14.03.2016, 18:44)Sebastiaan Wrote: Hi everyone, You are using LAN camera addressess instead of external addresses. If you can't make a VPN connection you must add this cameras but with external addresses like your LM. RE: IP camera URL - Erwin van der Zwart - 15.03.2016 Hi, And port (; If your external IP address is 123.124.125.126 and your forwarding is on port 82 then your url should look like this: http://user:password@123.124.125.126:82/stream1.mjpg BR, Erwin RE: IP camera URL - Sebastiaan - 15.03.2016 Thanks for the replies, this is exactly what i thought. Maybe i should affort a VPN router then, because i'm behind a variable wanIP at home. RE: IP camera URL - admin - 16.03.2016 VPN is recommended as it is much more secure than port forwarding |
