SpaceLYnk Telegram - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: SpaceLYnk Telegram (/showthread.php?tid=2509) |
SpaceLYnk Telegram - adiaz - 12.03.2020 Hi, We have Telegram API working on LogicMachines. We copy the same code on SpaceLynk and it not works.. Is posible to make it work on SpaceLynk? Thanks! RE: SpaceLYnk Telegram - Joep - 12.03.2020 Check your network settings. Make sure you have a working internet connection at your spaceLYnk. If it can't communicate to the internet it can't communicate with the API or if it's a local device make sure your spaceLYnk is in the same network as your API device (like Philips Hue gridge or so). RE: SpaceLYnk Telegram - adiaz - 12.03.2020 Network is OK. Code used is: local telegram_url = 'https://api.telegram.org/'..token_bot..'/sendMessage?' function telegram(message) local data_str = 'chat_id=' .. chat_id .. '&text=' .. message..'' local res, code, headers, status = ssl.https.request(telegram_url, data_str) log (res,code,headers,status) end Log Response: * arg: 1 * nil * arg: 2 * string: error:1409442E:lib(20):func(148):reason(1070) * arg: 3 * nil * arg: 4 * nil Not working! Thanks! |
