How to get luasql.mysql package ? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: How to get luasql.mysql package ? (/showthread.php?tid=2525) |
How to get luasql.mysql package ? - olivier - 18.03.2020 Hi all, Hope you are all well & healthy More generally, I would like to know how / where to search / get packages that are compatible with LogicMachine ? In this case it is for "luasql.mysql" package (I search unsuccessfully within the forum, maybe I miss it, if so, sorry) I suppose that such package (once downloaded) can be installed via "system config" panel / "system/package" menu ? I have the following error: ---------------- Resident script:1: module 'luasql.mysql' not found: no field package.preload['luasql.mysql'] no file './luasql/mysql' no file 'Library luasql/mysql' no file 'Library luasql/mysql' no file 'Library luasql/mysql.so' no file 'Library luasql.so' stack traceback: [C]: in function 'require' ---------------- Best regards RE: How to get luasql.mysql package ? - Daniel - 19.03.2020 Here for imx6 cpu https://dl.openrb.com/lm-19-imx6/pkg/ RE: How to get luasql.mysql package ? - olivier - 19.03.2020 thanks a lot for your quick response ! seems no to be the right architecture ![]() a screenshot of my system / errors additionnel question : this package is a standalone one or I will need to install additional dependency's package ? Best regards RE: How to get luasql.mysql package ? - Snoolik - 19.03.2020 (19.03.2020, 13:23)olivier Wrote: thanks a lot for your quick response ! Try for another architecture: https://dl.openrb.com/lm-19-mxs/pkg/ RE: How to get luasql.mysql package ? - admin - 19.03.2020 You need package for mxs, but install libmysqlclient first RE: How to get luasql.mysql package ? - olivier - 19.03.2020 Perfect !! thank you !! liblua-mysql_2.2.0-6_mxs.ipk + dependencies libmysqlclient_5.1.73-1_mxs.ipk zlib_1.2.11-1_mxs.ipk Best regards |
