 irrigazione con sensore pioggi - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: irrigazione con sensore pioggi (/showthread.php?tid=2609)  |
irrigazione con sensore pioggi - Hosutech - 23.04.2020 Good morning everyone, I ask you top experts if there is a preconfigured script (macro) for the management of 4/8 irrigation areas that provides the possibility of: - schedule the start of the irrigation cycle for each zone and for a defined time for each individual zone, a sort of sequence scenario that starts the zones active in the cycle successively one after the other, - insert a block for each zone to allow one or more specific zones to be blocked in the cycle, - activate the irrigation block according to the rain sensor (1bit from a digital input), - insert a filter for each zone that brings a reduction in the preset irrigation time based on comparison with a soil humidity sensor (example: zone 1 - time 10 'if soil moisture value> 40% 20% reduction .. then will be 8 '), I await kind support and feedback, thank you RE: irrigazione con sensore pioggi - admin - 23.04.2020 Here's a similar script that has configurable enable and timer value via objects: https://forum.logicmachine.net/showthread.php?tid=362&pid=8161#pid8161 RE: irrigazione con sensore pioggi - Joep - 23.04.2020 Hi Hosutech, I once made a very simple script for this. Please find a copy below. It's a start of what you need but you need to extend it with some extra functionality but that al are simple conditions i would say.. start_stop = grp.getvalue('15/2/0') -- start stop minuten = grp.getvalue('15/2/1') -- time per section (minutes, byte value) sectie_1 = grp.getvalue('15/2/3') -- section 1 sectie_2 = grp.getvalue('15/2/4') -- section 2 sectie_3 = grp.getvalue('15/2/5') -- section 3 sectie_4 = grp.getvalue('15/2/7') -- section 4 minuten = minuten * 60 -- time calculation to minutes stored_pomp_pid = storage.get('storage_pomp_pid') if stored_pomp_pid == nil then pid = os.getpid() storage.set('storage_pomp_pid', pid) else pid = os.getpid() storage.set('storage_pomp_pid', pid) os.kill(stored_pomp_pid, signal.SIGKILL) end if start_stop == true then if sectie_1 == true then grp.write('0/2/3', true) -- section 1 os.sleep(minuten) -- time per section grp.write('0/2/3', false) -- section 1 end if sectie_2 == true then grp.write('0/2/4', true) -- section 2 os.sleep(minuten) -- time per section grp.write('0/2/4', false) -- section 2 end if sectie_3 == true then grp.write('0/2/5', true) -- section 3 os.sleep(minuten) -- time per section grp.write('0/2/5', false) -- section 3 end if sectie_4 == true then grp.write('0/2/7', true) -- section 4 os.sleep(minuten) -- time per section grp.write('0/2/7', false) -- section 4 end else grp.write('0/2/3', false) -- section 1 grp.write('0/2/4', false) -- section 2 grp.write('0/2/5', false) -- section 3 grp.write('0/2/7', false) -- section 4 end RE: irrigazione con sensore pioggi - Hosutech - 27.04.2020 (23.04.2020, 14:45)Joep Wrote: Hi Hosutech,Thanks JOEP I try your script and let you know. To make good (23.04.2020, 14:42)admin Wrote: Here's a similar script that has configurable enable and timer value via objects:well thanks, I try it and let you know  |
