Wrong clock - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Wrong clock (/showthread.php?tid=2613) |
Wrong clock - camillsg - 27.04.2020 Hi! When I log my objects, the time in 'Object logs' do not correspond to the watch on my computer. The time in LM4 is always showing approx. 38 minutes before the real time. Does anyone know why this is? And what can I do to get the right time? Kind regards, Camilla RE: Wrong clock - Daniel - 27.04.2020 Sync time and set correct time zone. Make sure LM has access to the internet so it will sync its time with NTP. RE: Wrong clock - camillsg - 27.04.2020 (27.04.2020, 09:41)Daniel. Wrote: Sync time and set correct time zone. Make sure LM has access to the internet so it will sync its time with NTP. Thank you! LM is connected to the internet through ethernet-cable, so it should be able to sync its time through that.. but it is still not giving the right time.. I have set correct time zone in my computer, but will I have to do this in LM aswell? RE: Wrong clock - Daniel - 27.04.2020 Did you set correct gateway and dns in IP settings? without this it can't connect. RE: Wrong clock - camillsg - 28.04.2020 (27.04.2020, 10:12)Daniel. Wrote: Did you set correct gateway and dns in IP settings? without this it can't connect. I will check this! Thank you! |
