Bacnet limits - Printable Version
+--- Thread: Bacnet limits (/showthread.php?tid=2676)
Bacnet limits - pentadom - 04.06.2020
I have to map to knx 255 bacnet objects from an Intesis gateway.
This is the intesis Gateway integration manual: https://cdn.hms-networks.com/docs/librariesprovider11/manuals-design-guides/user-manuals/ac-interfaces/user-manual-inbacpanxxxo000.pdf?sfvrsn=923650d7_4
I have 15 indoor units in the installation and I would like to map 17 objects from each machine.
There is any limitation in the number of bacnet objects I can map to knx?
RE: Bacnet limits - Daniel - 04.06.2020
The Bacnet Client app will not handle it, it was design for small amount of objects per device around 50. You can have more device but with smaller amount of objects.
You can try to do it by script, it will work the question is how quick.
