Frames - Printable Version
+--- Thread: Frames (/showthread.php?tid=2678)
Frames - sjfp - 08.06.2020
need some advise on how to get around this scenario.
A remote site (lots of sites) use a frame to display event logs (thanks Daniel and others) on the main vis screen.
Works great and thanks for the help in getting the LP file sorted to do this.
But now the Central site which is used to monitor all site, uses frames to bring back a page view from each remote site, by using a script to adjust the URL.
Again works fine apart from the event log frame. which now shows an error 404 Not Found.
Is there a way to show this data ??
Thanks for any help.
RE: Frames - Daniel - 08.06.2020
Hi try using URL like this in frame
/user/logs.lp?obj=1/1/1
RE: Frames - sjfp - 08.06.2020
sorry to say, no effect. still the same.
The URL with frame should be in remote LM but in the Master LM you should use link with IP to a dedicated page on this LM.
That's how we set up, re-did the URL's in the custom JAVA script, and all working now thank you.
