Integration to Hunter Irrigation - Printable Version
+--- Thread: Integration to Hunter Irrigation (/showthread.php?tid=2776)
Integration to Hunter Irrigation - mjaanes - 05.08.2020
Greetings,
I am not new to LM/LUA, but new to doing external interfacing from these.
I need to integrate LM/Wiser to Hunter Irrigation (Hydrawise via the HC controller).
Has anybody done that?
Hunter states that they have two APIs:
  • RESTful API
  • Graph QL & oAuth 2.0 API
(source: https://support.hydrawise.com/hc/en-us/articles/360008965753-Account-API-Information)
Which one of these do you recommend I spend time learning in order to integrate?
Thanks in advance
Christian
RE: Integration to Hunter Irrigation - Daniel - 06.08.2020
Restful API is simpler option. If you send me to PM your API Key I can try to make you an example.
Integration to Hunter Irrigation - mjaanes - 08.08.2020
Thanks a lot for the quick answer. I followed your advice an succeeded contacting the HC. Was easier than I thought.
Sent from my iPhone using Tapatalk
RE: Integration to Hunter Irrigation - tpospichal - 29.08.2022
(08.08.2020, 07:46)mjaanes Wrote: Thanks a lot for the quick answer. I followed your advice an succeeded contacting the HC. Was easier than I thought.
Hello do you successfully integrate Hydrawise with the scripts? If yes can you share them to the forum to make life easier for another integrators?
Thank you.
Tomas
