Homelynk Admin Password - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Homelynk Admin Password (/showthread.php?tid=2789) |
Homelynk Admin Password - tstalzer - 12.08.2020 Hello I have "inherited" a KNX project with a homelynk server installed. Unfortunately, the previous integrator is no longer available for the project and the current administrator password is unknown. For the visualization part, a new setup would not be that difficult however he implemented some "magic" logic modules which also are not documentet. Is there a way to get hold of the admin password without resetting the machine? Would it be possible to read the current project from the e.g. SD card, reset the system and load the project again into the system? Thanks for your help --Thomas RE: Homelynk Admin Password - admin - 12.08.2020 It's not possible to recover the password. But it can be changed if you can access the SD card from Linux. RE: Homelynk Admin Password - tstalzer - 13.08.2020 (12.08.2020, 14:21)admin Wrote: It's not possible to recover the password. But it can be changed if you can access the SD card from Linux. That sounds very interesting. Yes, I can access the SD Card from Linux. Could you give me details on how to change it? Thank you !! RE: Homelynk Admin Password - admin - 13.08.2020 Sent via PM RE: Homelynk Admin Password - Gadjoken - 19.10.2020 Hello, Can you send me the procedure ? B.R. RE: Homelynk Admin Password - esteve.budia - 18.11.2020 (13.08.2020, 13:39)admin Wrote: Sent via PM Can you also send me the process? thx RE: Homelynk Admin Password - rahi - 20.09.2021 (12.08.2020, 14:21)admin Wrote: It's not possible to recover the password. But it can be changed if you can access the SD card from Linux. That sounds very interesting. Yes, I can access the SD Card from Linux. Could you give me details on how to change it? Thank you !! RE: Homelynk Admin Password - stefan_vvv - 11.05.2022 Hi, Could you please send me the way to do it to? Thank you in advance! KR Stefan RE: Homelynk Admin Password - braty2006 - 26.01.2023 Hi. Can you help me too. I can access the SD Card from Linux kaly. Could you give me details on how to change password? RE: Homelynk Admin Password - legolas2069 - 16.02.2023 Hello, could you please send me the process? RE: Homelynk Admin Password - max123rr - 10.08.2023 (13.08.2020, 13:39)admin Wrote: Sent via PM Hello, could you please send me the process? RE: Homelynk Admin Password - nmedalacabeza - 13.10.2023 Hello, could you please send me the process? Thank you in advance! RE: Homelynk Admin Password - nmedalacabeza - 27.10.2023 (13.10.2023, 21:35)nmedalacabeza Wrote: Hello, could you please send me the process? RE: Homelynk Admin Password - VikHae - 13.08.2025 Hello I'm also in this situation where the admin password is unknown. I would be very pleased to get the information about the process to change the password
RE: Homelynk Admin Password - Daniel - 13.08.2025 Hardware factory reset. RE: Homelynk Admin Password - VikHae - 14.08.2025 Thats the last alternative. It would be convenient to be able to just change the password, as i dont have any backup of the system and dont want to re-program everything. RE: Homelynk Admin Password - jlfneira - 11.03.2026 Hello, I've just received an installation where integrator not longer is active and there isn't admin password. Can you send me procedure to reset admid password please? RE: Homelynk Admin Password - Daniel - 11.03.2026 Hardware factory reset. |
