Text Visualitzation - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Text Visualitzation (/showthread.php?tid=279) |
Text Visualitzation - jmir - 17.04.2016 Is it possible with the viewer to display a text from a KNX address value? For example from 1 byte KNX address: value = 0 --> text = auto value = 1 --> text = heating value = 2 --> text = cooling Thanks! RE: Text Visualitzation - buuuudzik - 17.04.2016 (17.04.2016, 07:53)jmir Wrote: Is it possible with the viewer to display a text from a KNX address value? If I understand you well, you must use a function "Custom values" in "Objects" tab and in every object there is such option. RE: Text Visualitzation - jmir - 17.04.2016 (17.04.2016, 08:55)buuuudzik Wrote:(17.04.2016, 07:53)jmir Wrote: Is it possible with the viewer to display a text from a KNX address value? It's just I needed! Thanks! |
