Bacnet server - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Bacnet server (/showthread.php?tid=2802) |
Bacnet server - Tokatubs - 21.08.2020 I have exported knx objects to bacnet. The integrator on the other side have som questions if anybody have an answer: Properties missing on Bacnet (EDE-exports and scans). State-texts for multistate and digital objects (values, inputs and outputs). Is this a limitation on Logic machine or are there a setting that can be added. Also is there some limitation on how many objects that can be exported from the LM? And whats the latest bacnet package ? RE: Bacnet server - Daniel - 21.08.2020 We don't use EDE export, we have our export to csv. Multi state is not supported for bacnet server as KNX has no multi-state objects. RE: Bacnet server - Tokatubs - 21.08.2020 (21.08.2020, 12:36)Daniel. Wrote: We don't use EDE export, we have our export to csv. Multi state is not supported for bacnet server as KNX has no multi-state objects.Thanks for info. Also is there some limitation on how many objects that can be exported from the LM? And whats the latest bacnet package ? RE: Bacnet server - Daniel - 21.08.2020 As always it is hard to define the limit. It depend of other conditions like amount of scripts, high KNX terrific etc. I know projects where 2-3k were done. Latest package is in latest FW RC3 RE: Bacnet server - Erwin van der Zwart - 21.08.2020 (21.08.2020, 12:36)Daniel. Wrote: We don't use EDE export, we have our export to csv. Multi state is not supported for bacnet server as KNX has no multi-state objects. You can make a EDE file with YABE, do a discovery and create the EDE RE: Bacnet server - zoltan - 28.08.2020 (21.08.2020, 12:29).Tokatubs Wrote: Also is there some limitation on how many objects that can be exported from the LM? I'm not sure if this is still actual info, but check this. I have a few dozen devices that export over 2500 Bacnet points each without problems, some of them run KNX > Bacnet and some are running a single script readout russian Merkurii meters then exporting that data to bacnet - again 1000-2500 points per device. |
