Boolean object operations - Printable Version
+--- Thread: Boolean object operations (/showthread.php?tid=2807)
Boolean object operations - davidchispas - 25.08.2020
I need to do a sum with 1 bit objects, is this possible?
For example,
a = 1/1/1 (true)
b = 1/1/2 (false)
c = 1/1/3 (true)
value = 1/1/4
a + b + c = value
*in this operation it would send a value 2
RE: Boolean object operations - admin - 25.08.2020
Like this:
objs = {   '1/1/1',   '1/1/2',   '1/1/3', } sum = 0 for _, obj in ipairs(objs) do   if grp.getvalue(obj) then     sum = sum + 1   end end grp.checkwrite('1/1/4', sum)
RE: Boolean object operations - davidchispas - 25.08.2020
(25.08.2020, 14:29)admin Wrote: Like this:
Thank you so much Admin!  Smile
