Import font failed - Printable Version
+--- Thread: Import font failed (/showthread.php?tid=2826)
Import font failed - buuuudzik - 03.09.2020
I'm trying to import font which was already imported on other LM with older firmware on the LM5 with current firmware and I have response that "Unable to get font info from file".
I am trying to recover especially tahoma_regular.ttf but also I tried others with same result.
I am attaching font which I am trying to use (with changed extension from .ttf to .txt so I can attach it).
RE: Import font failed - Daniel - 04.09.2020
I tried different ttf and it works fine, it must be something wrong with this file.
RE: Import font failed - admin - 04.09.2020
The file is corrupted. Tahoma is a part of default Windows fonts, you can copy it from any Windows PC.
RE: Import font failed - buuuudzik - 04.09.2020
