Set filtered group addresses current value - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Set filtered group addresses current value (/showthread.php?tid=2830) |
Set filtered group addresses current value - usyntax - 04.09.2020 Hello, There are possible to set all filtered group addresses (in LM interface) same value? I don't want to set values one by one. Also, i don't want to write script which set those values. RE: Set filtered group addresses current value - Daniel - 04.09.2020 Hi I'm not sure if I understand your question correct. Do you want to from LM object tab write a value to many objects at once? This is not possible. What you can do is filter what you want then use mass edit and add a tag to them and then simple script with 2 lines will do. BR RE: Set filtered group addresses current value - usyntax - 04.09.2020 (04.09.2020, 10:33)Daniel. Wrote: Hi Thank you for answer. You understand my question correctly. I thought that interface have this function. |
