Control KNX Dimmer lights with Alexa App - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Control KNX Dimmer lights with Alexa App (/showthread.php?tid=2834) |
Control KNX Dimmer lights with Alexa App - Hyxion14 - 08.09.2020 When we configure a knx dimmable light in the alexa app in LM: Should we create two devices: in the first device we configure a "power State" skill with the 1-bit KNX objects and in the second device we configure a "percentage" skill with the 1-byte objects? Or, do we create a single device, with two skills, one for 1-bit objects in the power state skill and the other skill for 1-byte objects? Thank you. RE: Control KNX Dimmer lights with Alexa App - Daniel - 08.09.2020 One device and as many skills the device support. RE: Control KNX Dimmer lights with Alexa App - Hyxion14 - 08.09.2020 (08.09.2020, 13:17)Daniel. Wrote: One device and as many skills the device support. Thanks Daniel, in the case of a KNX dimmabe light, what skill should we use: percentage or brightness? I don't know what the difference is. RE: Control KNX Dimmer lights with Alexa App - Daniel - 08.09.2020 They both are the same, the only difference is later label in alexa app on mobile if you use it. RE: Control KNX Dimmer lights with Alexa App - Hyxion14 - 08.09.2020 (08.09.2020, 14:25)Daniel. Wrote: They both are the same, the only difference is later label in alexa app on mobile if you use it. Okay, Thanks Daniel. |
