Modbus TCP 2.0 - Without any adress? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus TCP 2.0 - Without any adress? (/showthread.php?tid=2876) |
Modbus TCP 2.0 - Without any adress? - sx3 - 29.09.2020 Hello, I'm trying to hookup a Modbus slave, that is Modbus TCP 2.0 compatible. It isn't possible to set the modbus adress on the device, and according to the manufacturer it isn't needed. Here is a example code for "home assistant" from the manufacturer; Quote:modbus: How do I handle this type of configuration with LM2/HomeLynk? I can't leave the modbus adress blank when creating a device. I'm running version: Version: 20170620 EDIT: As for now I have set the adress to "0" and worte a simple JSON for 1 register. But the LM isn't returning values for me. The devices are on the same LAN, I can ping the slave from the LM. Quote:"manufacturer": "Mani Cheraghi", EDIT 2: I also have a ModBus RTU device over RS485.. Just checking, is it possible to run both RTU and TCP in the same time? RE: Modbus TCP 2.0 - Without any adress? - sx3 - 29.09.2020 I'm feeling a bit stupid now. I didn't realize that I have to map to a KNX adress before values pop up, anyway.. Tried mapping and it works now. Assigned adress 0 RE: Modbus TCP 2.0 - Without any adress? - sx3 - 30.09.2020 I have another question about how Modbus TCP works. Is the connection between LM and slave always established or does the LM, connect-->Poll-->disconnect-->polling intervall-->connect.... and so on? Because my TCP slave says there is no connection to a master, but the LM manages to read out from it. The supplier of modbus slave says to connection normally stays connected. RE: Modbus TCP 2.0 - Without any adress? - admin - 01.10.2020 Default behavior is connect-read/write-disconnect. In newer firmware there's an option to keep the TCP connection open between read/write operations. It is needed by some slave devices that have a limited connection pool. |
