customize a circular slider - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: customize a circular slider (/showthread.php?tid=2880) |
customize a circular slider - davidchispas - 01.10.2020 Hello, I want to customize a circular slider. I need the plus / minus buttons to look as big as possible. Then I have seen that it is possible to customize the color of the temperature bar but I was not able to achieve it. I want it to be Blue in Cold mode and Red in Heat mode. RE: customize a circular slider - admin - 01.10.2020 For color change see this post: https://forum.logicmachine.net/showthread.php?tid=2120 If using default blue color then hue-rotate(160deg) filter will change it to red. To make up/down icons bigger use this custom CSS: Code: .circularslider-min, .circularslider-max {
font-size: 34px;
}RE: customize a circular slider - davidchispas - 02.10.2020 Hello, from the mobile access the thermostat is displayed wrong. Do you know why this happens? RE: customize a circular slider - admin - 02.10.2020 Which hardware and browser version is that? RE: customize a circular slider - davidchispas - 05.10.2020 (02.10.2020, 15:34)admin Wrote: Which hardware and browser version is that?From Safari browser in IOS updated to the latest version RE: customize a circular slider - admin - 06.10.2020 Can you send backup via PM? |
