Dinamic IP - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Dinamic IP (/showthread.php?tid=2886) |
Dinamic IP - CristianAgata - 03.10.2020 Hi everybody, is it possible using my LM know my actual public IP and show it? Best regards Cristian RE: Dinamic IP - admin - 05.10.2020 Create a scheduled script that runs every 5 minutes: Code: ip = require('ssl.https').request('https://openrb.com/ip/')
if ip then
grp.checkupdate('0/0/1', ip:trim())
endChange 0/0/1 as needed, make sure that data type is set to "250 byte string". RE: Dinamic IP - CristianAgata - 05.10.2020 (05.10.2020, 06:23)admin Wrote: Create a scheduled script that runs every 5 minutes:Thank you so much RE: Dinamic IP - d.r soutras - 23.09.2021 Hello guys! A little bit of a help on how to set schedule. The help of w4k and the manual doesn't seems to be helpful for me. The goal was to run every 5 minutes but it doesn't work. RE: Dinamic IP - admin - 23.09.2021 Does the script work when run manually? Check that you have valid gateway and DNS settings in System Config > Network > Interfaces > eth0. RE: Dinamic IP - admin - 23.09.2021 grp.checkupdate will send anything only when the value changes. You can add log(ip) at the end of the script to check if it works as it should. RE: Dinamic IP - d.r soutras - 23.09.2021 Yes manually works fine. I assume that it doesn't work because it doesn't update the value in the objects sector at the "Updated at" tab. (23.09.2021, 10:03)admin Wrote: grp.checkupdate will send anything only when the value changes. You can add log(ip) at the end of the script to check if it works as it should. Thank you! |
