Modbus Gateway Schneider Electric Em3155 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus Gateway Schneider Electric Em3155 (/showthread.php?tid=29) |
Modbus Gateway Schneider Electric Em3155 - PassivPluss - 09.07.2015 Hi. I cannot get the modbus to work correctly to communicate with iEM3155 on Modbus, parameters inserted correctly but there is no place to choose stop bits in LM, the iEM has 1 stop bit. Is that OK? I tried to modify the Json file to the correct settings for reading adresses but i only get 0 value. I tried one up and one down register also. Any ideas? i can also add that the iEm3155s Communication LED blinks when trying to read registers. RE: Modbus Gateway Schneider Electric Em3155 - admin - 10.07.2015 Stop bit settings are merged with parity in order to prevent invalid values, you can choose from:
If you have a valid device profile you can use scan feature to discover your device. If scan works properly it means that settings are correct and reading should work as well. RE: Modbus Gateway Schneider Electric Em3155 - PassivPluss - 10.07.2015 Of course. But I still get no communication. Ii example i want to read the following register from the manuafactors table: Register Address Action (R/W/WC) Size Type Units Description Current 3000 R 2 Float32 A I1: phase 1 current 3002 R 2 Float32 A I2: phase 2 current 3004 R 2 Float32 A I3: phase 3 current 3010 R 2 Float32 A Current Avg Voltage 3020 R 2 Float32 V Voltage L1–L2 3022 R 2 Float32 V Voltage L2–L3 3024 R 2 Float32 V Voltage L3–L1 3026 R 2 Float32 V Voltage L–L Avg 3028 R 2 Float32 V Voltage L1–N 3030 R 2 Float32 V Voltage L2–N 3032 R 2 Float32 V Voltage L3–N 3036 R 2 Float32 V Voltage L–N Avg I then made the json file: { "manufacturer": "Passiv Pluss", "description": "Strømmåling", "mapping": [ { "name": "Gjennomsnitt A", "bus_datatype": "float32", "type": "inputregister", "address": 3010 } ] } I also tried register instead of inputregister. I want to use the modbus function 3 for reading and 16 for writing to registers as noted under. Modbus parameters from IEM3155 Function list The table below lists the supported Modbus functions: For example: • To read different parameters from the meter, use function 3 (Read). • To change the tariff, use function 16 (Write) to send a command to the meter. Table format Decimal Hexadecimal 3 0x03 Read Holding Registers 16 0x10 Write Multiple Registers 43/14 0x2B/0x0E Read Device Identification Type Description Range UInt16 16 bit unsigned integer 0 – 65535 Int16 16 bit signed integer -32768 to +32767 UInt32 32 bit unsigned integer 0 – 4 294 967 295 Int64 64 bit unsigned integer 0 – 18 446 744 073 709 551 615 UTF8 8 bit field multibyte character encoding for Unicode Float32 32 bit value Standard representation IEEE for floating number (with single precision) iEM 3155 instructions for downloading RE: Modbus Gateway Schneider Electric Em3155 - edgars - 15.07.2015 The best way to integrate this Modbus device is by using a profile file, this will exclude all possible scripting mistakes. |
