Nano Temp Inveo - Temperature Sensor - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Nano Temp Inveo - Temperature Sensor (/showthread.php?tid=2936) |
Nano Temp Inveo - Temperature Sensor - Hugo - 26.10.2020 Preface: Manual: http://download.inveo.com.pl/manual/nano_t/user_manual_en.pdf Module: https://www.tme.eu/at/en/details/nano-temp/industrial-networks/inveo/nano-temp/ Note: I try out several third-party sensors, but only the original Inveo sensors are working. Sensors: https://www.tme.eu/at/en/details/sensor-ds-1/temp-sensors-resistance-thermometers/inveo/ds-1/ https://www.tme.eu/at/en/details/sensor-ds-5/temp-sensors-resistance-thermometers/inveo/ds-5/ https://www.tme.eu/at/en/details/sensor-ds-10/temp-sensors-resistance-thermometers/inveo/ds-10/ Question: By the following .jons i get the output of 231°C (since it`s x 10 in accordance to the Manual) { "manufacturer": "Hugo", "description": "Nano_Temp_Inveo_V1", "mapping": [ { "name": "Temperatur", "bus_datatype": "int16", "datatype": "int16", "type": "register", "address": 4003, "units": "°C" } ] } But if i do this, i get the output of 23°C { "manufacturer": "Hugo", "description": "Nano_Temp_Inveo_V2", "mapping": [ { "name": "Temperatur", "bus_datatype": "int16", "datatype": "int16", "type": "register", "address": 4003, "value_multiplier": 0.1, "units": "°C" } ] } How i get the output 23,1°C? RE: Nano Temp Inveo - Temperature Sensor - Erwin van der Zwart - 27.10.2020 You have the wrong bus datatype, you need to use 2 byte float.. RE: Nano Temp Inveo - Temperature Sensor - Hugo - 28.10.2020 Thanks, it's 23.1 ° C now. { "manufacturer": "Hugo", "description": "Nano_Temp_Inveo_V2", "mapping": [ { "name": "Temperatur", "bus_datatype": "float16", "datatype": "int16", "type": "register", "address": 4003, "value_multiplier": 0.1, "units": "°C" } ] } |
