Problem importing knx to LM - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Problem importing knx to LM (/showthread.php?tid=2943) |
Problem importing knx to LM - Josema - 28.10.2020 Good evening: Today I had problems when importing the ETS project, when importing it (OPC Export) not all the group addresses appear, has it ever happened to you? Before I imported the projects through https://openrb.com/knxproj/, but the website gave me an "error", can you tell me how you import your projects? Thank you RE: Problem importing knx to LM - Erwin van der Zwart - 29.10.2020 OPC export only exports addresses that holds objects and empty addresses are skipped, you can use a dummy device to fill them them with correct dpt objects if needed. RE: Problem importing knx to LM - josemabera - 29.10.2020 (29.10.2020, 01:16)Erwin van der Zwart Wrote: OPC export only exports addresses that holds objects and empty addresses are skipped, you can use a dummy device to fill them them with correct dpt objects if needed.Thanks Erwin for the answer But i have the dummy and the address linked in the device, but still those addresses do not appear in the LM RE: Problem importing knx to LM - admin - 29.10.2020 In 2020 firmware you can import knxproj directly without any additional conversion. |
