Telnet communication with Biamp Tesira - Printable Version
+--- Thread: Telnet communication with Biamp Tesira (/showthread.php?tid=2945)
Telnet communication with Biamp Tesira - Martin Rogstad - 29.10.2020
I have a project where we need to control source and volume level on a Biamp Tesira system from a KNX display.
This involves communication via Telnet.
I tried to search for similar solutions in here, but only found something for Denon.
Is there anyone here who can show me how to open a Telnet session with this system?
https://support.biamp.com/Tesira/Control/Telnet_session_negotiation_in_Tesira
If anybody want to take this scripting job for me, please let me know.
I am now familiar with advanced scripting.
RE: Telnet communication with Biamp Tesira - Erwin van der Zwart - 29.10.2020
Try this:
local host, port = "192.168.2.60", 23 local socket = require("socket") local tcp = assert(socket.tcp()) tcp:connect(host, port) tcp:settimeout(0.5) --Set command command = string.char(0xFF,0xFD,0x01) -- Do Echo -- Write command tcp:send(command .. '\r') --or try Write command --tcp:send(command) --Get Reply local s, status, partial = tcp:receive()   --Check if reply has a value if s then     --Do your action(s) with replies     if s == string.char(0xFF,0xFC,0x01) then      log('Wont Echo')     end     loghex(s) end tcp:close()
RE: Telnet communication with Biamp Tesira - Martin Rogstad - 29.10.2020
Thank you, will try this!
