pause event script - Printable Version
+--- Thread: pause event script (/showthread.php?tid=2974)
pause event script - Frank68 - 12.11.2020
Hello
In case there is a bus reset or a disconnection, if possible I would like the event scrips to be evaluated after a certain settable period at bus return, otherwise I would have suffered a series of alarms, how can this be done?
RE: pause event script - admin - 12.11.2020
This is not possible. You can add some extra checks so your scripts do not continue execution if a certain condition is not met.
Something like this, but you will need another script to control the bus_connected variable state.
if not storage.get('bus_connected') then   return end -- rest of the script
