Scenes Issue - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Scenes Issue (/showthread.php?tid=2978) |
Scenes Issue - gdimaria - 13.11.2020 Hi, I created some scenes that are only called by the tag. I had left the object and value fields blank and it seemed to work fine. Then I added a second tag and from that moment the scenes have completely stopped working. After several attempts I tried to insert a virtual object and a random value and everything started working again. So I would like to know if it is mandatory to enter subject and value or is it just a bug. Thanks Peppe RE: Scenes Issue - Daniel - 13.11.2020 Hi, I don't know how it worked for you without the trigger object but it should not. Scene must have trigger object and you can use as many tags you want. RE: Scenes Issue - gdimaria - 13.11.2020 (13.11.2020, 09:35)OK, Thanks! Daniel. Wrote: Hi, I don't know how it worked for you without the trigger object but it should not. Scene must have trigger object and you can use as many tags you want. |
