Virtual objects only for visualisation - Printable Version
+--- Thread: Virtual objects only for visualisation (/showthread.php?tid=299)
Virtual objects only for visualisation - buuuudzik - 12.05.2016
Do you know if there is a possibility to use some virtual objects which are not visible in KNX TP and KNX IP? This will be very helpful especially when I use some texts on a visualisation.
I've tried use a function "grp.update()" and menu "Apply filter virtual objects" but still telegrams are visible on IP sideSad
RE: Virtual objects only for visualisation - admin - 12.05.2016
Which connection mode are you using? If you enable "Apply filter virtual objects" then both internal (grp.write/grp.update) and TP telegrams will be filtered by rules specified in "TP > IP filter". If this option is not set then all grp.update telegrams are sent to IP.
RE: Virtual objects only for visualisation - buuuudzik - 12.05.2016
(12.05.2016, 10:30)admin Wrote: Which connection mode are you using? If you enable "Apply filter virtual objects" then both internal (grp.write/grp.update) and TP telegrams will be filtered by rules specified in "TP > IP filter". If this option is not set then all grp.update telegrams are sent to IP.
I am using "EIBnet/IP Routing" mode now. I've read your answer and tested this function and it works.
Solution:
"Apply filter virtual objects" enabled
TP>IP filtered object
Thanks for good help and good device LMWink
For now this filter only work for TP-UART connection modes, I'll check if it can be added for Routing as well.
(12.05.2016, 11:59)admin Wrote: For now this filter only work for TP-UART connection modes, I'll check if it can be added for Routing as well.
It works also in Routing mode. I checked this on my installation I have LM4 and LMLB connected via KNX IP and when I did things which I mentioned above it works fine. I saw only telegram on LM4 and not on LMLB. But when I disable the filter TP>IP telegram is appearing on both busmonitors.
