"Pause" function in a script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: "Pause" function in a script (/showthread.php?tid=3006) |
"Pause" function in a script - legolas2069 - 23.11.2020 Hi, I have a Sonos system and a Homelynk, and I want to control a large script, so that I can pause it. I wrote the following script: 1-General structure: if value_n then -play sonos -do some knx -Every X orders, I call to stop the function and check if I pressed the button. end I have 15 if like this in 8k lines. 2- Function stop (), where I compare in a group address and I pause Sonos if a button is pushed. I do os.sleep (1) until the button is released. When I run the script without interruptions it works, but when I try it with the stop function the homelynk starts to work slow. I am doing something wrong? (Sure I am xD) Thank you for your help. RE: "Pause" function in a script - Daniel - 23.11.2020 You probably have infinite loop. RE: "Pause" function in a script - legolas2069 - 25.11.2020 (23.11.2020, 16:13)Daniel. Wrote: You probably have infinite loop. Perhaps, I was wondering if this was the problem. Today I will try with a simple script to see if I get it. Thanks! |
