mail sending issue - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: mail sending issue (/showthread.php?tid=3019) |
mail sending issue - gdimaria - 25.11.2020 Hi, I never had that issue but today, trying to send a mail by a wiser for Knx Schneider I got the attached message. The same mail script works fine on LM. Ps. I had already set gmail security option to work with apps with less security. RE: mail sending issue - admin - 25.11.2020 This probably happens because your device has different IP than the one that you are using to access the account. My suggestion is to try one of these services instead: https://sendpulse.com/ https://www.mailjet.com/ https://sendgrid.com/ Gmail is not really meant for automated sending and this feature can be blocked at any time. RE: mail sending issue - gdimaria - 26.11.2020 Instead of your suggestions, may we use one of our business mail (microsoft mail)? Or we will have the same problem? RE: mail sending issue - admin - 27.11.2020 MS email should work, but better to try it yourself. RE: mail sending issue - gdimaria - 30.11.2020 I 'm testing our business mail, that are the parameters: Impostazione SMTP Nome server: smtp.office365.com Porta: 587 Metodo di crittografia: TLS in common fuctions I have local settings = { -- "from" field, only e-mail must be specified here from = 'segnalazioni.tecniche@komponext.it', -- smtp username user = 'segnalazioni.tecniche@komponext.it', -- smtp password password = 'xxxxxxxx', -- smtp server server = 'smtp.office365.com', -- smtp server port port = 587, -- enable ssl, required for gmail smtp secure = 'sslv23', } I have to change or disable secure = 'sslv23' since I will use 587 port? RE: mail sending issue - admin - 30.11.2020 Try secure = "starttls" for port 587 if secure = "tlsv1_2" does not work. RE: mail sending issue - gdimaria - 30.11.2020 ok... it seems to be working with secure = "starttls". Thanks RE: mail sending issue - Trond Hoyem - 05.01.2021 (27.11.2020, 08:26)admin Wrote: MS email should work, but better to try it yourself. Hi I have had the same issues as described in this thread. I tried now the solution with MS, and that worked. I have one question thouh; If I have the mail settings in a userlibrary where the 'Keep source' is unchecked, is it 100% impossible to get to the library later? The reason I ask is clear; I will have to enter company-sesitive information in the mail settings, and if it in any way is possible to read these settings later, this would be a big problem. RE: mail sending issue - admin - 06.01.2021 Hiding the source will provide some level of protection but it is still possible to retrieve the credentials from the backup file. I don't see a big security risk if you create a separate e-mail account for LM notifications. RE: mail sending issue - Trond Hoyem - 07.01.2021 (06.01.2021, 08:09)admin Wrote: Hiding the source will provide some level of protection but it is still possible to retrieve the credentials from the backup file. I don't see a big security risk if you create a separate e-mail account for LM notifications. OK, thanks for answer. I tested also the services you mentioned in an earlier post. I think I will go for one of them, then there is only the risk of giviing away credentials to a free service that is in no other way linked to my company. Thx for help. |
