TCP connection - Printable Version
+--- Thread: TCP connection (/showthread.php?tid=304)
TCP connection - buuuudzik - 18.05.2016
I must connect with a device which is a gateway for CAN-based system via TCP which sends and receive frames with RAW data.
Do you know how can I create such mechanism?
Frame size is from 29 to 37 bytes and this is start-bit: "0F" and this is stop-bit: "04".
I've tried based on available other integration manuals and all did is that I can send to the bus command and it works:
require('socket') ip = '192.168.0.15' port = 10001 cmd = string.char(0x0F, 0x00, 0x10, 0x00, 0x00, 0x80, 0x01, 0x00, 0x01, 0x04, 0x00, 0x01, 0x00, 0x00, 0x5A, 0x04) sock = socket.tcp() sock:settimeout(3) res, err = sock:connect(ip, port) if res then  res, err = sock:send(cmd)  if res then    print('send OK')  else    print('send failed: ' .. tostring(err))  end else  print('connect failed: ' .. tostring(err)) end sock:close()
But this is easier than receiving data and checking from which point the frame startsSad
