Streaming MJPEG blocked - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Streaming MJPEG blocked (/showthread.php?tid=3046) |
Streaming MJPEG blocked - SigmaTec - 05.12.2020 Hi all, I use currently Foscam cameras (streaming and API's) without problems, but I'm trying to work with an Hikvision one and I got this message : LM Camera page > console/F12 = "Subresource requests whose URLs contain embedded credentials (e.g. `https://user:pass@host/`) are blocked" This cam (under Chrome) works perfectly with the url http://user:client01!@192.168.1.64:80/ISAPI/Streaming/channels/102/httpPreview witch is the same I use in the LM. Any idea ? All the best from France. RE: Streaming MJPEG blocked - Daniel - 07.12.2020 Which model is it? RE: Streaming MJPEG blocked - SigmaTec - 07.12.2020 an HIKVISION one, DS-2DE2A204IW-DE3/W RE: Streaming MJPEG blocked - Daniel - 07.12.2020 Try turning off authentications and check if it works. https://www.hikvision.com/content/dam/hikvision/en/support/download/how-to/ipc/How%20to%20Get%20IPC%20MJPEG%20Stream%20via%20HTTP%20Commands.pdf RE: Streaming MJPEG blocked - SigmaTec - 14.12.2020 Thank's Daniel, but I work yet with this doc. No solution for HIKVISION, I return to use FOSCAM Cam's witch work perfectly with CGI commands. Have a good week. |
