RS485 at 250k - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: RS485 at 250k (/showthread.php?tid=3069) |
RS485 at 250k - equalizer - 19.12.2020 I have a unsusual problem. I have an Av system firing a nonstandard (but known) serial string once per second on a RS485 line at the nonStandard speed of 250k. (Its an old system and not changable, I assume as they are AV people and they liked 250k due to DMX...). The problem I have is I can't open the RS485 port at 250k, is this possible via script? Would opening at this speed be possible on a USB 485 port? Or do I need to buy/build a hardware buffer to convert the baud rate to a more standard speed I can open a port at. Robert. RE: RS485 at 250k - admin - 21.12.2020 Not possible at the moment but the luaserial library can be updated to support non-standard baud rates. I'll let you know when it's ready. RE: RS485 at 250k - admin - 21.12.2020 Updated serial package with custom baud rate support: https://dl.openrb.com/pkg/luaserial_20201221_imx6.ipk RE: RS485 at 250k - equalizer - 21.01.2021 (21.12.2020, 14:27)admin Wrote: Updated serial package with custom baud rate support: Hi. This is great :-) I just visited the site and they have a MX28 cpu. Can I be cheeky and ask for a MX28 cpu version :-) , or will above version work on the old CPU? Robert. RE: RS485 at 250k - admin - 21.01.2021 Package for old CPU: https://dl.openrb.com/pkg/luaserial_20201221_mxs.ipk RE: RS485 at 250k - equalizer - 18.02.2021 Thank you, I have now tested this with the real non-standard speed serial data source and it works great :-) |
