Open LM4 device - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Open LM4 device (/showthread.php?tid=3081) |
Open LM4 device - baggins - 28.12.2020 OK, so I found out I have a read-only SD card (actually two of them). Now I've had this before and replaced it then, but I completely forgot how I physically changed it Do I have to remove the device from the DIN rail? How do I open the device? I can find nothing in the manual on this subject and I don't want to break things... TIA. RE: Open LM4 device - Daniel - 28.12.2020 You need to power it down and take it of the panel. Remove the bottom part and then the PCB. You will find the card there. RE: Open LM4 device - baggins - 28.12.2020 (28.12.2020, 12:32)Daniel. Wrote: You need to power it down and take it of the panel. Remove the bottom part and then the PCB. You will find the card there. OK thanks. |
