Custom Javascript function not working anymore with FW2020 - Printable Version
+--- Thread: Custom Javascript function not working anymore with FW2020 (/showthread.php?tid=3099)
Custom Javascript function not working anymore with FW2020 - hummelsystemhaus - 11.01.2021
we recently updated some of our Controller from FW20180828 to the new "stable" 2020 version.
Now a bunch of our Custom JavaScript Functions for the Visu don't work anymore.
Is this due to Errors in the Code?
/*** RTR ***/   $('.reve-rtr').each(function(index){     /* data:         object: Setpoint Adr       statusObject: Is-Value Adr         1) create new element for Setpoint       2) add listener for Setpoint     */     var curEle = $(this);     var knxAdr = curEle.data();     var setPoint = grp.find(knxAdr.object);     /* create new element */     curEle.find('.control-button').append('<button class="btn control-value disabled">( S: ' + setPoint.value.toFixed(2) + setPoint.units + ' )</button>');     /* listener for changed-Value */     grp.listen(knxAdr.object, function(object, state){       curEle.find('.control-button > button:last-child').html('( S: ' + object.value.toFixed(2) + object.units + ' )');     }, true);   });     /*****************/   /*** Jalousien ***/   /* scale */   $('.reve-jal').each(function(index){     /* data:         object: Lamelle Position Status Adr       statusObject: Postion Status Adr         1) create new element for Lamelle       2) add listener for Lamelle     */     var curEle = $(this);     var knxAdr = curEle.data();     var lamPos = grp.find(knxAdr.object);     /* create new element */     curEle.find('.control-button').append('<button class="btn control-value disabled" style="padding:0px;">/</button>');     curEle.find('.control-button').append('<button class="btn control-value disabled">' + lamPos.value + '%</button>');     /* listener for changed-Value */     grp.listen(knxAdr.object, function(object, state){       curEle.find('.control-button > button:last-child').html(object.value + '%');     }, true);   });   /* step */   $('div').filter(function(){     /* filter the onoff buttons */     return this.className.match(/reve-jal-step/);   }).each(function(index){     /* data         object: Move Adress       statusObject: Stop Adress     */     var curEle = $(this);     var knxAdr = curEle.data();     var stepAdr = knxAdr.object;     var stopAdr = knxAdr.statusObject;     var controlEle = curEle.find('.control');     var invert = $(this).hasClass('reve-jal-step-invert');     /* add Buttons */     controlEle.empty()     var upEle = $('<button class="btn icon">&#x2191;</button>');     var stopEle = $('<button class="btn icon btn-error">×</button>');     var downEle = $('<button class="btn icon">&#x2193;</button>');         controlEle.append(upEle);     controlEle.append(stopEle);     controlEle.append(downEle);     /* add click events */     upEle.click(function(){       grp.write(stepAdr, invert);     });     stopEle.click(function(){       grp.write(stopAdr, true);     });     downEle.click(function(){       grp.write(stepAdr, !invert);     });   }); /*** On/Off Buttons ***/   $('div').filter(function(){     /* filter the onoff buttons */     return this.className.match(/reve-onoff/);   }).each(function(index){     var curEle = $(this);     var knxAdr = curEle.data();     var useSecure = $(this).hasClass('reve-onoff-secure');     /* clear normal button */     curEle.find('.control').empty();     /* create Buttons */     var offBtn = $('<button class="btn icon">×</button>');     var onBtn = $('<button class="btn icon btn-success">✓</button>');     curEle.find('.control').append(offBtn);     curEle.find('.control').append(onBtn);     /* add listener */     function cbOn(){       grp.write(knxAdr.object, true);     }     function cbOff(){       grp.write(knxAdr.object, false);     }     offBtn.click(function(){       if(useSecure){         showPincode(grp.getvalue(secureCodeAdr), {callback: cbOff});       }       else{         cbOff();       }     });     onBtn.click(function(){       if(useSecure){         showPincode(grp.getvalue(secureCodeAdr), {callback: cbOn});       }       else{         cbOn();       }     });   });
RE: Custom Javascript function not working anymore with FW2020 - admin - 11.01.2021
showPincode function has been changed. For security reasons PIN check has been moved to the server side so this function cannot be used to make custom PIN checks anymore.
