Smappee inifinity Energy Monitoring to KNX - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Smappee inifinity Energy Monitoring to KNX (/showthread.php?tid=3115) |
Smappee inifinity Energy Monitoring to KNX - bednarekluc - 20.01.2021 Hello, I'm looking for a way to integrate the energy monitoring system from Smappee (www.smappee.com) into my KNX home visualization. The Smappee device sends its data to a MQTT Broker in a JSON format. I have tried to modify the existing examples from the forum to get the data out of the MQTT broker. But I get no where. Is there anybody around here who can help with this or has done this integration. Topic for subscription : servicelocation/uuid/config Sample of the data (this sample has 26 live power values in it) : {"totalPower":4421,"totalReactivePower":-1827,"totalExportEnergy":3067200,"totalImportEnergy":2775754800,"monitorStatus":0,"utcTimeStamp":1611127010000,"measuredFrequency":50012728,"channelPowers":[{"publishIndex":0,"formula":"$5500013892/0$","power":931,"exportEnergy":46800,"importEnergy":616680000,"phaseId":0,"current":51,"apparentPower":1214,"cosPhi":76},{"publishIndex":1,"formula":"$5500013892/1$","power":3113,"exportEnergy":615600,"importEnergy":545688000,"phaseId":1,"current":136,"apparentPower":3214,"cosPhi":96},{"publishIndex":2,"formula":"$5500013892/2$","power":377,"exportEnergy":2354400,"importEnergy":523616400,"phaseId":2,"current":20,"apparentPower":475,"cosPhi":79},{"publishIndex":3,"formula":"$5500013892/3$","power":15,"exportEnergy":0,"importEnergy":182869200,"phaseId":1,"current":2,"apparentPower":43,"cosPhi":33},{"publishIndex":4,"formula":"$5500013906/0$","power":0,"exportEnergy":43200,"importEnergy":23965200,"phaseId":0,"current":1,"apparentPower":14,"cosPhi":0},{"publishIndex":5,"formula":"$5500013906/1$","power":0,"exportEnergy":7200,"importEnergy":23475600,"phaseId":1,"current":1,"apparentPower":14,"cosPhi":0},{"publishIndex":6,"formula":"$5500013906/2$","power":0,"exportEnergy":0,"importEnergy":23691600,"phaseId":2,"current":1,"apparentPower":15,"cosPhi":0},{"publishIndex":7,"formula":"$5500013906/3$","power":91,"exportEnergy":0,"importEnergy":2113200,"phaseId":1,"current":6,"apparentPower":148,"cosPhi":61},{"publishIndex":11,"formula":"$5500024954/3$","power":281,"exportEnergy":0,"importEnergy":61390800,"phaseId":2,"current":14,"apparentPower":333,"cosPhi":84},{"publishIndex":12,"formula":"$5500024970/0$","power":28,"exportEnergy":0,"importEnergy":11750400,"phaseId":0,"current":3,"apparentPower":74,"cosPhi":37},{"publishIndex":13,"formula":"$5500024970/1$","power":2763,"exportEnergy":0,"importEnergy":153662400,"phaseId":1,"current":122,"apparentPower":2874,"cosPhi":96},{"publishIndex":14,"formula":"$5500024970/2$","power":88,"exportEnergy":0,"importEnergy":216208800,"phaseId":2,"current":6,"apparentPower":135,"cosPhi":65},{"publishIndex":15,"formula":"$5500024970/3$","power":80,"exportEnergy":0,"importEnergy":16171200,"phaseId":1,"current":5,"apparentPower":121,"cosPhi":65},{"publishIndex":16,"formula":"$5500024993/0$","power":0,"exportEnergy":0,"importEnergy":25848000,"phaseId":2,"current":0,"apparentPower":6,"cosPhi":5},{"publishIndex":17,"formula":"$5500024993/3$","power":51,"exportEnergy":0,"importEnergy":72860400,"phaseId":0,"current":2,"apparentPower":54,"cosPhi":93},{"publishIndex":18,"formula":"$5500024993/1$","power":530,"exportEnergy":0,"importEnergy":188485200,"phaseId":0,"current":28,"apparentPower":658,"cosPhi":80},{"publishIndex":19,"formula":"$5500024993/2$","power":140,"exportEnergy":0,"importEnergy":45691200,"phaseId":0,"current":9,"apparentPower":225,"cosPhi":62},{"publishIndex":20,"formula":"$5500024996/0$","power":13,"exportEnergy":0,"importEnergy":1807200,"phaseId":1,"current":2,"apparentPower":36,"cosPhi":35},{"publishIndex":21,"formula":"$5500024996/1$","power":74,"exportEnergy":0,"importEnergy":10317600,"phaseId":1,"current":4,"apparentPower":102,"cosPhi":72},{"publishIndex":22,"formula":"$5500024996/2$","power":6,"exportEnergy":0,"importEnergy":12020400,"phaseId":1,"current":2,"apparentPower":42,"cosPhi":13},{"publishIndex":23,"formula":"$5500024996/3$","power":35,"exportEnergy":0,"importEnergy":6868800,"phaseId":1,"current":3,"apparentPower":81,"cosPhi":42},{"publishIndex":24,"formula":"$5500024954/0$","power":11,"exportEnergy":0,"importEnergy":7365600,"phaseId":1,"current":1,"apparentPower":26,"cosPhi":41},{"publishIndex":25,"formula":"$5500024954/1$","power":24,"exportEnergy":0,"importEnergy":2001600,"phaseId":1,"current":2,"apparentPower":40,"cosPhi":60},{"publishIndex":26,"formula":"$5500024954/2$","power":4,"exportEnergy":0,"importEnergy":1206000,"phaseId":1,"current":0,"apparentPower":11,"cosPhi":30}],"voltages":[{"voltage":238,"phaseId":0},{"voltage":236,"phaseId":1},{"voltage":239,"phaseId":2}]} Best regards, Luc RE: Smappee inifinity Energy Monitoring to KNX - admin - 20.01.2021 Have you managed to check if that data is being published to the broker? You can use this application to connect to the broker: http://mqtt-explorer.com/ From the docs it looks like the correct topic for data is servicelocation/<UUID>/realtime where <UUID> must be replaced with the unique ID. Or you can simply subscribe to servicelocation/+/realtime to receive data from all devices. RE: Smappee inifinity Energy Monitoring to KNX - bednarekluc - 20.01.2021 (20.01.2021, 07:40)admin Wrote: Have you managed to check if that data is being published to the broker? You can use this application to connect to the broker: http://mqtt-explorer.com/ Yes, I got the sample data from the broker with the app MQTTOOL. The problem is that I don’t have a clue how to get the Jason data into the logicmachine from the broker. RE: Smappee inifinity Energy Monitoring to KNX - admin - 20.01.2021 Resident script (sleep time = 0), log(msg) will output the received real-time data decoded from JSON. Code: if not broker then
require('json')
require('socket')
broker, port = '127.0.0.1', 1883
mclient = require('mosquitto').new()
mclient.ON_CONNECT = function(res, rc, msg)
log('mqtt connect status', res, rc, msg)
if res then
mclient:subscribe('servicelocation/+/realtime')
mclient:disconnect()
mclient.ON_MESSAGE = function(mid, topic, payload)
local msg = json.pdecode(payload)
if type(msg) == 'table' then
log(msg)
mclient.ON_DISCONNECT = function(...)
log('mqtt disconnect', ...)
mclientfd = nil
mclient.ON_ERROR = function(...)
log('callback error', ...)
function mconnect()
local fd
mclient:connect(broker, port)
fd = mclient:socket()
-- fd ref is valid
if fd then
mclientfd = fd
mconnect()
-- run timer every 5 seconds
timer = require('timerfd').new(5)
timerfd = socket.fdmaskset(timer:getfd(), 'r')
-- mqtt connected
if mclientfd then
mclientfdset = socket.fdmaskset(mclientfd, mclient:want_write() and 'rw' or 'r')
res, timerstat, mclientstat = socket.selectfds(10, timerfd, mclientfdset)
-- mqtt not connected
res, timerstat = socket.selectfds(10, timerfd)
if res then
if mclientfd and mclientstat then
if socket.fdmaskread(mclientstat) then
mclient:loop_read()
if socket.fdmaskwrite(mclientstat) then
mclient:loop_write()
if timerstat then
-- clear armed timer
timer:read()
if mclientfd then
mclient:loop_misc()
mconnect()
endRE: Smappee inifinity Energy Monitoring to KNX - bednarekluc - 20.01.2021 (20.01.2021, 09:19)admin Wrote: Resident script (sleep time = 0), log(msg) will output the received real-time data decoded from JSON. Thanks this works perfect. RE: Smappee inifinity Energy Monitoring to KNX - Amelie - 06.06.2023 I'm also trying to import the data from the Smappee to the logic machine. I have use the script above, and I think it is working. The output I get is: Quote:LogicMachine Uitloggen StartpaginaTaal: But, how I nog put a value into an address, so I can use it? RE: Smappee inifinity Energy Monitoring to KNX - admin - 06.06.2023 Put this instead of log(msg). Adjust group addresses and data fields as needed. Code: grp.checkupdate('32/1/0', msg.totalPower)
grp.checkupdate('32/1/1', msg.totalImportEnergy)
grp.checkupdate('32/1/2', msg.voltages[1].voltage)
grp.checkupdate('32/1/3', msg.voltages[2].voltage)
grp.checkupdate('32/1/4', msg.voltages[3].voltage) |
