Bacnet- Spacelynk - Printable Version
+--- Thread: Bacnet- Spacelynk (/showthread.php?tid=3123)
Bacnet- Spacelynk - stephan - 24.01.2021
Hallo,
ich finde über das Bacnet app keine Geräte. Übe die software Yabe finde ich alles.
RE: Bacnet- Spacelynk - admin - 25.01.2021
Please post in English next time. Make sure that you have BACnet server disabled when running the client application.
RE: Bacnet- Spacelynk - stephan - 02.02.2021
the server is deactivated. if I hang a wide spacelynk in as a server, I can also find it in the client. Only the two other Bacnet devices are not. But in the software Yabe I find all devices.
RE: Bacnet- Spacelynk - Daniel - 03.02.2021
How many objects does your bacnet server has?
Try running this script, this is manual scan.
res = io.readproc('bacwi') log(res)
RE: Bacnet- Spacelynk - stephan - 03.02.2021
There are 10 objects per Bacnet server. I test the script maker.
the devices are found via the script
bacnet 03.02.2021 19:53:21
* string: 100 192.168.188.120
4194303 192.168.188.120
2 192.168.188.172
192.168.188.39: Wiser for Knx Bacnet Client script executed
192.168.188.120: Spacylink Bacnet Server
192.168.188.172: Deos Ventilation unit
192.168.188.173: Deos Ventilation unit currently not in the network
