Infinite loop - Printable Version
+--- Thread: Infinite loop (/showthread.php?tid=3130)
Infinite loop - Angeles - 26.01.2021
I think I have had a mistake and I've created an infinite loop and now the lm is unreachable.
How can I access system to stop the script?
thanks.
RE: Infinite loop - Daniel - 26.01.2021
You can try to reboot it via power cycle and maybe you will be quick enough to get in. If this is not possible then hardware factory reset. Press for 10 sec reset button till LED will flash red then release and press again for 10 sec. LED will flash faster.
RE: Infinite loop - admin - 26.01.2021
An infinite loop should not block the device completely. Unless you have a .lp file that blocks the web server. Factory reset via the button as Daniel suggested should do the trick.
