Read RS232 send to KNX Group adress - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Read RS232 send to KNX Group adress (/showthread.php?tid=3131) |
Read RS232 send to KNX Group adress - AndersH - 27.01.2021 Hi. Is it anyone who knows how to read from RS232 and send forward to a KNX group adress. i will receive 4 different values that should call for a scene on the KNX side.... 0/r, 1/r, 2/r and 3/r, i have seen some script examples but how do i make it send to the KNX group adress require('serial') port = serial.open('/dev/RS232', { baudrate = 38400, databits = 8, stopbits = 1, parity = 'none', duplex = 'full' }) This must be to open the port, but the rest i don`t know how, i think it must be some "port:read" and "write to" Best regards RE: Read RS232 send to KNX Group adress - admin - 27.01.2021 Serial docs: https://openrb.com/docs/serial.htm RE: Read RS232 send to KNX Group adress - AndersH - 27.01.2021 Thanks, but how do i transfer received value to KNX group adress ? RE: Read RS232 send to KNX Group adress - Daniel - 27.01.2021 It depend of the application. You may need to convert the data and then write to object as to any other object. The simplest way is to make If received string is X then write to object Y etc. RE: Read RS232 send to KNX Group adress - admin - 27.01.2021 See this example: https://forum.logicmachine.net/showthread.php?tid=746&pid=4224#pid4224 You just need to add several if's and grp.write calls RE: Read RS232 send to KNX Group adress - AndersH - 27.01.2021 Ok, i will try and reply how it goes Thanks RE: Read RS232 send to KNX Group adress - AndersH - 03.02.2021 I tried this script.... but something must be wrong in the log it says "* string: port not open" RE: Read RS232 send to KNX Group adress - admin - 03.02.2021 Try this script (resident, sleep time = 0) as is without changing anything and post what you get in Alerts tab: Code: if not port then
require('serial')
port = serial.open('/dev/RS232', { baudrate = 9600 })
port:flush()
line = ''
char = port:read(1, 1)
if char then
if char == '\r' then
line = line:trim()
alert(line)
line = ''
line = line .. char
endRE: Read RS232 send to KNX Group adress - AndersH - 03.02.2021 I got nothing in the log .... RE: Read RS232 send to KNX Group adress - admin - 03.02.2021 Are you sure that data is being sent to the port? Try this and post what you get in Logs tab. Code: if not port then
require('serial')
port:flush()
line = ''
char, err = port:read(1, 60)
log(char, err)RE: Read RS232 send to KNX Group adress - AndersH - 03.02.2021 This came up now... RE: Read RS232 send to KNX Group adress - admin - 03.02.2021 This should accept strings in X/r format where X is a number between 0 and 3: Code: char = port:read(1, 1)
if char then
if char == 'r' then
if #line == 2 and line:sub(2, 2) == '/' then
value = tonumber(line:sub(1, 1))
if value and value >= 0 and value <= 3 then
grp.write('1/1/1', value)
alert(line)
line = ''
line = line .. char
endRE: Read RS232 send to KNX Group adress - AndersH - 03.02.2021 And before this it should be to open the port ? RE: Read RS232 send to KNX Group adress - Daniel - 03.02.2021 Yes this Code: if not port then
require('serial')
port:flush()
line = ''
endRE: Read RS232 send to KNX Group adress - AndersH - 03.02.2021 Ok, sorry but i get nothing now on the log, i don´t know what is wrong. RE: Read RS232 send to KNX Group adress - Daniel - 03.02.2021 Check alerts not logs. Start logging the object 1/1/1 or which ever you used in the script RE: Read RS232 send to KNX Group adress - AndersH - 03.02.2021 This is how the script looks now.. RE: Read RS232 send to KNX Group adress - admin - 03.02.2021 Anything in the Alerts tab? Add a new line with log(line) after if char then, and post what you get in the Logs tab RE: Read RS232 send to KNX Group adress - AndersH - 05.02.2021 I had some things between will check it on monday. TY RE: Read RS232 send to KNX Group adress - AndersH - 10.02.2021 Hi, the problem is solved the script is working fine.... Thank you very much for the support //Anders |
