luadmx library - Printable Version
+--- Thread: luadmx library (/showthread.php?tid=3159)
luadmx library - AndrejHanus - 10.02.2021
Where can I find details or documentation about luadmx library please? Only thing I found are scripts which uses DMX.set() function. I would like to do script for dimming (different from that one and only available on internet).
Thank you
RE: luadmx library - admin - 15.02.2021
luadmx functions:
dmx = require('luadmx').open(port) -- open port and create DMX instance dmx:send() -- send current channel values to DMX dmx:setchannel(channel, value) -- set channel (1..512) to the given value (0..255) value = dmx:getchannel(channel) -- get channel (1..512) value dmx:setcount(count) -- set number of channels to send (1..512) count = dmx:getcount() -- get number of channels to send dmx:setall(value) -- set all channels to the given value (0..255)
RE: luadmx library - managementboy - 16.02.2021
(15.02.2021, 08:25)admin Wrote: luadmx functions:
Hi! does this mean I can change my old "DMX" user library for this internal?
RE: luadmx library - admin - 16.02.2021
There's no point unless you have some custom DMX control you want to use which cannot be created with the DMX library. The library uses luadmx internally anyway.
