Bacnet client app not fetching all bacnet devices - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Bacnet client app not fetching all bacnet devices (/showthread.php?tid=3160) |
Bacnet client app not fetching all bacnet devices - Rajesh - 10.02.2021 I am using LM5 KDC for knx -Bacnet ip integration for AC controlling. I installed Bacnet client app in LM5. After scanning it shows the 28 devices with their device ID. But when I scanned same bacnet bus by another software it shows that there are 30 devices. 2 devices are not shown by rescanning in Bacnet client app.I try to restart the Bacnet server but still not problem solved. If I try to delete the one of the Bacnet device from client app then how to recover this deleted device RE: Bacnet client app not fetching all bacnet devices - Daniel - 11.02.2021 Can you try to install our backnet package and see if this will find all? https://dl.openrb.com/lm-20-imx6/pkg/genohm-scada-bacnet_20190828_imx6.ipk System-System-Packages. You will have new tab in LM. RE: Bacnet client app not fetching all bacnet devices - Rajesh - 11.02.2021 (11.02.2021, 08:37)Daniel. Wrote: Can you try to install our backnet package and see if this will find all? During scanning it shows the error "cannot run scan while local BACnet server is running on the same port" (11.02.2021, 10:26)Rajesh Wrote:(11.02.2021, 08:37)Daniel. Wrote: Can you try to install our backnet package and see if this will find all? The BACnet devices which is not showing app that will now showing in BACnet tab (11.02.2021, 10:26)Rajesh Wrote:(11.02.2021, 08:37)Daniel. Wrote: Can you try to install our backnet package and see if this will find all? Please reply RE: Bacnet client app not fetching all bacnet devices - Daniel - 11.02.2021 You cant use bacnet server and client at the same time. You must disable it as it says. RE: Bacnet client app not fetching all bacnet devices - Rajesh - 11.02.2021 (11.02.2021, 10:49)Daniel. Wrote: You cant use bacnet server and client at the same time. You must disable it as it says. How it will be disable RE: Bacnet client app not fetching all bacnet devices - Daniel - 11.02.2021 Go to system, interface, bacnet and disable bacnet server. RE: Bacnet client app not fetching all bacnet devices - Rajesh - 11.02.2021 (11.02.2021, 11:22)Daniel. Wrote: Go to system, interface, bacnet and disable bacnet server. The ac which not showing in app now it showing in BACnet tab but how to link group address (11.02.2021, 11:44)Rajesh Wrote:(11.02.2021, 11:22)Daniel. Wrote: Go to system, interface, bacnet and disable bacnet server. After installing package still 2 BACnet devices are not appear in Bacnet client app RE: Bacnet client app not fetching all bacnet devices - Daniel - 11.02.2021 The bacnet client app is not designed to work on any bigger installation. You will most likely need to stick to script https://openrb.com/logicmachine-as-bacnet-client/ RE: Bacnet client app not fetching all bacnet devices - Rajesh - 11.02.2021 (11.02.2021, 11:44)Rajesh Wrote:(11.02.2021, 11:22)Daniel. Wrote: Go to system, interface, bacnet and disable bacnet server. Please reply |
