Firmware downgrade possible? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Firmware downgrade possible? (/showthread.php?tid=3168) |
Firmware downgrade possible? - baggins - 14.02.2021 Hi, At the moment I have two LM4 with a read-only SD card. In the near future I will replace them with the usual procedure. At the moment they both use firmware 20160714. The reason for this is that during the upgrade to that version there were some issues with a third party library which is used for the ventilation system. The developer of this library cannot guarantee that there will be no problems with this library during an upgrade and on top of that he is very difficult to get hold of. Now this is what I would attempt to do:
Thanks for your advice. RE: Firmware downgrade possible? - admin - 14.02.2021 You can install older firmware if you use the recovery procedure. Direct firmware downgrade is not always supported because of some changes to the file locations or other internal logic changes. RE: Firmware downgrade possible? - baggins - 14.02.2021 (14.02.2021, 17:36)admin Wrote: You can install older firmware if you use the recovery procedure. Direct firmware downgrade is not always supported because of some changes to the file locations or other internal logic changes. Thanks, I'll give it a try then. Fingers crossed... |
