Using built-in MQTT broker over WebSocket - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Using built-in MQTT broker over WebSocket (/showthread.php?tid=3170) |
Using built-in MQTT broker over WebSocket - johanax - 16.02.2021 Hi, is it possible to set up the built-in Mosquitoo broker to use the websocket protocol? RE: Using built-in MQTT broker over WebSocket - admin - 16.02.2021 Websocket support is not enabled. Can you explain your use case for this? RE: Using built-in MQTT broker over WebSocket - johanax - 16.02.2021 I'm developing a web based smart home dashboard using the Paho JavaScript Client RE: Using built-in MQTT broker over WebSocket - admin - 16.02.2021 LM has a websocket interface for objects, do you really need MQTT in your case? See this thread for an example: https://forum.logicmachine.net/showthread.php?tid=525&pid=2913#pid2913 RE: Using built-in MQTT broker over WebSocket - johanax - 16.02.2021 (16.02.2021, 10:12)admin Wrote: LM has a websocket interface for objects, do you really need MQTT in your case? See this thread for an example: https://forum.logicmachine.net/showthread.php?tid=525&pid=2913#pid2913 I would prefer to use MQTT over websocket as a common protocol since I also will interact with other interfaces. Is there any problems/drawbacks to enable websocket support for the built-in broker. Regards Johan RE: Using built-in MQTT broker over WebSocket - admin - 16.02.2021 The broker does not have the websocket protocol support compiled in. RE: Using built-in MQTT broker over WebSocket - johanax - 16.02.2021 Will websocket support be compiled into the broker in a near future, if not is it possible to install a custom package with websocket support enabled? RE: Using built-in MQTT broker over WebSocket - admin - 16.02.2021 Maybe later but I can't promise anything at the moment. RE: Using built-in MQTT broker over WebSocket - johanax - 04.02.2023 Hi, any plans on implementing websocket support for MQTT in the future? Regards Johan RE: Using built-in MQTT broker over WebSocket - johanax - 07.02.2023 (04.02.2023, 08:08)johanax Wrote: Hi, Hi again, is it somehow possible to install a custom package with websocket support enabled? Regards Johan RE: Using built-in MQTT broker over WebSocket - admin - 07.02.2023 There's no custom package with websocket support. |
