Zero tier - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Zero tier (/showthread.php?tid=3207) |
Zero tier - benanderson_475 - 08.03.2021 Is there an package for the imx28cpu to use zero tier like this https://openrb.com/zerotier-remote-maintenance-of-lm5/ RE: Zero tier - benanderson_475 - 09.03.2021 (08.03.2021, 07:50)benanderson_475 Wrote: Is there an package for the imx28cpu to use zero tier like this 1457 views and nobody knows? i also tried https://openrb.com/zerotier-remote-maintenance-of-lm5/ on lm5 with imx6 cpu, i have installed the packages in step 6 but cannot find the Zero tier config option after installing the packages and rebooting, i confirm packages are installed, but step 9 as per above link, under services i cant find ZeroTier to enable it. 9. Go to System Configuration -> Services -> ZeroTier Must be something simple i am missing RE: Zero tier - Daniel - 10.03.2021 Which LM do you have? You need new firmware. RE: Zero tier - benanderson_475 - 10.03.2021 (10.03.2021, 09:23)Daniel. Wrote: Which LM do you have? You need new firmware. Lm5p2-DR RE: Zero tier - Daniel - 10.03.2021 Use this, https://dl.openrb.com/lm-20-imx6/lm5m3ex-20201111.img You will have to install the packages again. RE: Zero tier - Sral1987 - 10.03.2021 Is Zero Tier also with lm2i possible ? RE: Zero tier - Daniel - 10.03.2021 We didn't compile this for old cpu, for now not. RE: Zero tier - benanderson_475 - 10.03.2021 (10.03.2021, 09:59)Daniel. Wrote: Use this, https://dl.openrb.com/lm-20-imx6/lm5m3ex-20201111.img Thanks Daniel, i updated firmware as per link above and installed pkg again, i still not find the zero tier config tab after reboot RE: Zero tier - Daniel - 11.03.2021 Clear browser cache RE: Zero tier - benanderson_475 - 11.03.2021 (11.03.2021, 08:30)Daniel. Wrote: Clear browser cache Many thanks, i have it working now!! RE: Zero tier - stonecroft - 11.03.2021 Is this firmware also suitable for LM5p2-KC? RE: Zero tier - Daniel - 11.03.2021 Yes it is RE: Zero tier - savaskorkmaz - 16.06.2021 Hi , i cannot find zerotier packages for new and old cpu ? Can you share links please ? RE: Zero tier - Daniel - 16.06.2021 Just install RC1, old hw will not get zerotier. RE: Zero tier - savaskorkmaz - 05.07.2021 I have new hw lm5 lite. I updated Firmware. I will install the packages but i cannot find the packages. Can somebody share please ? RE: Zero tier - Daniel - 05.07.2021 If you installed RC1 then it is already there, no need to install packages anymore. RE: Zero tier - savaskorkmaz - 05.07.2021 Oh ok. It's because browser cache. Thank you. RE: Zero tier - iridium - 21.07.2022 Hi, Is Zero Tier already available for the old cpu? Thanks RE: Zero tier - admin - 22.07.2022 It's only available for the new CPU. |
