motion_cm-19 connet RS485 to LM5-RIO2 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: motion_cm-19 connet RS485 to LM5-RIO2 (/showthread.php?tid=3218) |
motion_cm-19 connet RS485 to LM5-RIO2 - luanpt - 12.03.2021 Dear all. I have a motor and a curtain controller. Please give me a guide for using over this RS485 protocol. I am using LM5-RIO2 I attach my controller's data.[/font] https://usermanual.wiki/Coulisse/CM19 Thanks you. RE: motion_cm-19 connet RS485 to LM5-RIO2 - admin - 12.03.2021 Create an event script attached to a 1-byte unsigned object (valid scene number is from 1 to 15), change CM-19 address (default is 1) and port (default is /dev/RS485-1) if needed. Code: addr = 1 -- CM-19 address (default 1)
scene = event.getvalue()
if scene > 0 and scene < 16 then
value = string.format('!BR%dg%X;', addr, scene)
port = require('serial').open('/dev/RS485-1', {
baudrate = 9600,
duplex = 'half'
port:write(value)
port:close()
endRE: motion_cm-19 connet RS485 to LM5-RIO2 - luanpt - 17.03.2021 (12.03.2021, 09:01)admin Wrote: Create an event script attached to a 1-byte unsigned object (valid scene number is from 1 to 15), change CM-19 address (default is 1) and port (default is /dev/RS485-1) if needed. Thanks admin support. |
