Alexa Command - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Alexa Command (/showthread.php?tid=3219) |
Alexa Command - Frank68 - 12.03.2021 Hello I am evaluating the possibility of using alexa with Logic Machine, one thing that is not clear to me. Do I need to install application and configure both Amazon.alexa cloud and LM cloud? Is there a minimum model required or is it compatible with all alexa. Do you accept commands in Italian? Thank you RE: Alexa Command - Daniel - 12.03.2021 You need to create account on our cloud https://cloud.logicmachine.net/user-management/auth/login And then you only need alexa app on LM. If you have Italian amazon account then it will work in Italian. RE: Alexa Command - Frank68 - 16.03.2021 (12.03.2021, 10:40)Daniel. Wrote: You need to create account on our cloud which version of alexa is required or recommended, is there a minimum version to use? Thank you RE: Alexa Command - Daniel - 16.03.2021 What do you mean by which version of Alexa? RE: Alexa Command - Frank68 - 16.03.2021 (16.03.2021, 12:12)Daniel. Wrote: What do you mean by which version of Alexa? not of alexa who is assistant but of echo which is hardware, can i take any model even the cheapest to try? RE: Alexa Command - Daniel - 16.03.2021 Yes any, even Sonos one. |
